epoxy
- Nov 9, 2012
I was wondering if it is normal that the oil lamp is on for about a minut or three when I´m doing a "cold" start?
What I mean is that the snowmobile have been outside for about a day or two in the cold and then I start it.
I have trippel checked the oil level and everything seems fine.
srxpert
- Apr 30, 2005
- Pembine wisconsin
- 2014 viper
Are you sure its not the water temp light?. That will stay on untill the sled is warm enough to drive. Shane
epoxy
- Nov 9, 2012
Yes, from my understanding the water temp light is the red one. I will not move the sled until that one have disappeared.srxpert said:Are you sure its not the water temp light?. That will stay on untill the sled is warm enough to drive. Shane
It´s the yellow light plus the oil picture on the display.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Mine dose the exact same thing sometimes when I start it in the really cold weather.(-30C and below) Most of the time for me it doesn't come on till I go to move the sled. Was a little concerning the first time it happened. Turn off the key and start it back up and it goes out though. Like you oil was fine so I've just ignored it since. Just something to do with the thicker oil I assume.
Ryan
Ryan
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
Mine does the same but seems to do it more often if the sled sits all night and isnt perfectly sitting on level ground
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
Had this happen to me last weekend...restated it and it went away. Scared the Sh*t outta me.
yox185
mike3577 said:Mine does the same but seems to do it more often if the sled sits all night and isnt perfectly sitting on level ground
Same here
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Are you running full synthetic?
mike3577
- Oct 18, 2009
- auburn hills,mi
I run full synthetic yamalube and it still does it sometimes
tankeryanker
Same here. Full synthetic and only if its sat outside for a few days. I shut it off and re-start it and all is good
Snakebit
Got me last Saturday morning at -5f. On-off and I was outta there...
EDIT: Mobil 1.
EDIT: Mobil 1.
epoxy
- Nov 9, 2012
I think so, have not changed oil since the levels are good and the last owner said he had changed for this season.canoehead said:Are you running full synthetic?
Yea this is something that I noticed yesterday, the sled was parked on level ground and then everything started without any issues.mike3577 said:Mine does the same but seems to do it more often if the sled sits all night and isnt perfectly sitting on level ground
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
When my sled sat in that deep cold it would do the same thing. Temp light would be on until it warms up, them yellow oil light would come on. Both times it would go out once the throttle was touched and rpms came up.
Spoke to my dealer, said it was no big deal. Sensors are just picking up the improper oil flow until oil gets more viscous and flows more freely.
If we continue to get cold snaps like that I would consider putting on the engine coolant heater (block heater) from Yamaha and plug it in for an hour or so prior to riding.
Ms
Ms
Old Thumper
Mine did it last year for the first time on a very cold morning. I added oil to bring the level up to Max on the dipstick, and did not get the light again last season.
It happened again last week on a -5F morning. I just ignored it because I knew the oil level was good, and the light went out as soon as I went a couple hundred feet.
Freefaller35
Mine does the same thing. The dealer told me it was from the oil settling into the base out of the oil canaster. The sensor is on the canaster and takes a while for the oil to get back up there which is why it goes out once it's been running a while. This is why it's so important to run the sled for 15 minutes before checking the oil. Just the opposite of what I do with everything else I own.
