Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Anybody ever have an oil leak on clutch side?
Trying to figure out where its coming from, only does it under high rpm (higher pressure). I let it run at idle and see nothing! Oil all underneath motor and back. Checked oil plug and filter they are tight. I see two sensors to the left of oil filter. Could they be leaking? Or maybe stub shaft leaking?
Any input would be appreciated!
Turboflash
- Mar 18, 2019
- Southern MN
There's been a very few sleds where the oil pressure sending unit leaked. It has the harness plug on it at bottom of engine. Points towards primary clutch.
Also possible it's the seal between the balance shaft and the impeller in water pump. There are 2 seals in there. One seals coolant from water pump side and the other seals oil from engine side. Maybe that one is leaking?
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
Yes I was looing at that too, oil pressure sending unit. So it would be the unit itself that is faulty? Or seal behind it? Its definitely right around there that i see a lot of oil!
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Check air filter, any oil in there?
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
No oil there, ever.Check air filter, any oil in there?
Its definitely bottom back, near that sensor or back of clutch
Turboflash
- Mar 18, 2019
- Southern MN
The seal is the unit itself. There is no separate seal behind it. If it's leaking, need new sending unit. I've replaced a few.Yes I was looing at that too, oil pressure sending unit. So it would be the unit itself that is faulty? Or seal behind it? Its definitely right around there that i see a lot of oil!
Turboflash
- Mar 18, 2019
- Southern MN
The one closest to primary on outside is the oil pressure sending unit. They're spendy (over $200 USD!). The other one behind it closer to oil filter is the oil pressure switch. That one isn't as bad (about $65 USD).
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Clean it off with brake clean and go run and re inspect. Bring flashlight and mirror with.
