yamaha06
So I changed the oil and filter in my sled a couple months ago, iv put 13 miles on this season and am heading north for the weekend so I figured o would check my oil level, I started the sled let it run for like 5 minutes checked the oil and it was just above the L on the dipstick, I let it run some more since i was messing around with some other stuff, the engine was hot at his point since the fan on the radiator was running,
I decided to check the oil level again and this time it was just above the H line. So with it being a like a hair above the H line after idling for a while could it do any damage?
kurtasaurus80
It wont do any damage; it will just puke it out into the airbox and eventually onto the ground.
raginyamaha
did u screw the sensor dipstick in to check?? Just supposed to slide it in to check the level. That will mess up ur level reading if you do that...
yamaha06
raginyamaha said:did u screw the sensor dipstick in to check?? Just supposed to slide it in to check the level. That will mess up ur level reading if you do that...
No I wasn't screwing it in, I'm going to check it again, how long do you guys usually run your sled before checking your oil?
Mtnviper
Vendor
yamaha06 said:raginyamaha said:did u screw the sensor dipstick in to check?? Just supposed to slide it in to check the level. That will mess up ur level reading if you do that...
I usually let mine run for approx 5 min.
