MXD
I just checked the oil in my 06 Apex and it looks WAY overfilled. Had it serviced 120 miles ago at the dealer and just figured I would check as we are going on a long trip this week. I started the sled in my trailer and let it get nice and hot with an occasional blip of the throttle for about 7-10 minutes. Then I let it idle for a minute or so and shut it off. I immediately pulled the dip stick, wiped it off then put it in and did NOT screw it down and the entire stick was covered in oil so I looked in the tank and the oil level was about 1-2 inches below the opening in the oil tank.
#1. Am I checking it correctly?
#2. If it is overfilled, did I do any damage riding it that way for 120 miles? The motor sounds a bit noisey for a few seconds when I start it up cold and it never did that before. Only 1400 miles
