Oil light?
B440
Newfoudland Canada
Just got the sled back from servicing at the dealer last week, took the sled for a small run in a field a few days ago for the first time this season. After a couple mins or riding the oil light came on. I stopped the sled right away and let rest. When I started it up again, no light came on but the same thing happened. Oil light came on just after a short burst. What could be causing this? The sled just got back from its service and I checked the oil to make sure the dealer forgot to put some back in and everything was fine, What else could be causing this problem?
P.S- my sled is a 08 nytro rtx
The oil is just a little two low,I had the same problem put about 1/8th of a quart and never had the problem again.
