APEXMAN
Hi all yama dudes was riding my 2011 er apex 1500 klms today outside temp was plus 7 shut it off then started it up 10 mins later and momenatery the OP-LO came on i no its oil pressure low just wondering if thats normal because of the hot outside temps iam using 0-W30 semi seynetic yamaha lube oil .. btw checked oil level and its good ... Another little issue is some sort of rattle just at take off sounds like it coming some where near the clutches thought maybe the pin that goes through the belt guard nott any other thought on that issue
doesnt sound like that famous clutch noise
Thxs 4 the replies
Steve
Thxs 4 the replies
Steve
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
It does that every time you start it, also if you start it and hit the throttle while that is displayed it will cut out.
APEXMAN
thxs for the replie kviper first time i have ever seen that displayed ever lols
kviper
- Nov 7, 2003
- Oakfield WI
I have a 2012 but it should be the same. Quite sure mine does it every time. I have noticed it many times but don't look every time I start it. Should be fine though.
vx700xtc
2013 does that every time
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
11's as well.
Mine does it everytime I start it up!
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I see the OP-LO every once in a while on my 2011 when starting just for for a second! First time I saw it is concerned me! Yami Mech says no biggy!
