Oil Question
Thanks good to know this my first go around with a 4stroke
Gone Blue said:
snow11 said:
Thanks for that info season has embed here so would be better to doya oil change now or weigh for fall
Now. You always want to change the oil at the end of the season before you store it for the summer. 4 stroke motors develop acid in the oil from use whicih can etch engine bearings when not in use.
G.B.
Unless it's full synthetic.
nswsparky said:
you know if you tip it on its left side it can dump the entire contents of the oil reservoir into the air intake.
Well you hit it spot on sure enough intake had oil in it wiped it out had to add quart of oil to it I did like someone said check it with the dip stick not screwed in hope that right
So hopping all is going to be ok put 100 miles on with low oil but warning light didn't come on till I was almost home
Thanks all for your help
