Travis Moore
Folks, I do not have a before picture, but my question is pretty simple, and the Bender guys will know how it looked before. But anyway, in the picture below, in the lower right corner, the "T" with the cap on it, which is the return line from the bender oil pump, originally had a line running from that 't' over to the "t" in the other large line on the top of the tank (i removed that "t" and just connected the lines) on the far left (not the one running next to the return line). As all those lines appear to just return oil to the oil tank, I saw no reason to have the line between them. I've since ran the sled and there seems to be no problems.
Do you guys that know the oiling system see any problems with this? Also, the line with the cap on it is just temporary...I'd never run it around with junk like that
Travis
Travis
