Chris Purvis
- Jan 8, 2017
- Markstay
- 2016 SR Viper LTX SE
Does the 2016 SR Viper have a dipstick to check engine oil level.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Yes
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
it tells you in your owners manual if you got one with the sled.
17 Viper XTX
- Jan 31, 2019
- Rockland, Ontario
- 2017 Yamaha Viper XTX
I have a 2017 Viper new to me and would like to know where the dipstick is. So you have to remove the hood?
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
No .you dont have to remove the hood.left side panel and black panel that covers gas tankI have a 2017 Viper new to me and would like to know where the dipstick is. So you have to remove the hood?
17 Viper XTX
- Jan 31, 2019
- Rockland, Ontario
Ok great. Thank you!No .you dont have to remove the hood.left side panel and black panel that covers gas tank
Carla 123
- Feb 27, 2017
- Lester beach
Sorry I meant right side panelOk great. Thank you!
17 Viper XTX
- Jan 31, 2019
- Rockland, Ontario
Exhaust side correct?Sorry I meant right side panel
Carla 123
- Feb 27, 2017
- Lester beach
Yes.right side when sitting on the sled.when checking oil warm the sled up then wait 30 seconds and screw the dipstick all the way in to get a correct reading.as long as you are between the upper and lower lines you are good to goExhaust side correct?
17 Viper XTX
- Jan 31, 2019
- Rockland, Ontario
Thanks for the info! I love this site. Such a great resource!Yes.right side when sitting on the sled.when checking oil warm the sled up then wait 30 seconds and screw the dipstick all the way in to get a correct reading.as long as you are between the upper and lower lines you are good to go
Imagemix
- Feb 1, 2019
- Toronto
- 17 SR Viper 137
Dealer told me that you do not thread dipstick in just insert and remove to check
TILAM1
- Jan 26, 2017
- 2017 SR Viper R-TX-SE
- Eastern Ontario
It has always been controversial as to how to measure it. I have mine halfway between the marks without screwing the dipstick in. Figure I'm safe either way. Manual isn't clear on which is correct.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
this is what I have done for the last 24000km and it has treated me good.
http://mountainperformance.com/Files/Download/hsk-1160_Layout.pdf
down at the bottom.
copy:
• Correct procedure for reading oil level.
• Level is always read by screwing the cap all the way in, then removed.
• Start with a cool vehicle on flat / level ground.
• Start vehicle and warm up for a few minutes (manual says till fan comes on). Typically once water has reached 150+deg F it is warm and variances from temp are gone.
• Shut motor off.
• Wait at least 30 sec, but no more than 90 sec to read oil level.
• Huge oil level reading variations have been observed. They are TIME & TEMPERATURE dependent.
• Highest level observed on warm motor with-in 60sec of shut-down.
• Level drops 60cc within 1 minute of above condition (would cause over-fill if customer used this reading).
• Lowest level observed on cold motor after only 30sec of run time (would cause 235cc over-fill).
• Oil level on cold motor and no run time is a little low (would cause 150cc over-fill)
• Reading oil level without screwing dip stick all the way in causes about 175cc over-fill in addition to above conditions.
down at the bottom.
copy:
• Shut motor off.
Anjill
- Mar 20, 2015
- NJ
- 2004 Warrior
2006 Attak
2013 Apex X-TX
Owner's manuals are available here.
https://www.yamahamotorsports.com/motorsports/owners-manuals
