APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I can't get it back on. I keep killing the gasket.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
APEX06
what do you mean,the y pipe wont slide toward the engine to reinstall the exhaust donuts clamp,
i had the same problem with mine what help was where you loosen the bolts for the y pipe if you look in there you will see like a flange in there that you can tap with whatever you can find and a hammer, just tap lightly and the y pipe will start to come forward again, even better while you are taping the y pipe have someone pull the y pipe forward at the same time, my right one was a little bit of a pain..
APEX 06
- Apr 30, 2009
- Sheboygan, WI
WinderFab
- Mar 1, 2009
- Woodbridge, ON
APEX06
is that the end that connects to the flex pipe..?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Into the headers.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
APEX06
i just did mine and for some reason they don't look the same,
how's the donut going so far in,
APEX 06
- Apr 30, 2009
- Sheboygan, WI
They still look new. It may look a little different I'm putting on a new Hauck pipe.
That gasket looks screwed. I think you need a new one.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Yeah back to my hind away-AKA Sheboygan yamaha.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
APEX06
sorry i thought you were having trouble with sliding the y pipe back into place towards to flex pipe..
Good luck, hope you get it going..
APEX 06
- Apr 30, 2009
- Sheboygan, WI
grader
you can add some slots with a hacksaw and open the pipe up a bit, then grease the gasket and it will slide in easier. stinks a bit when started but works well.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
The gasket goes on the male end first then it slides into the pipe.
sherlock29
*******The gasket goes on the male end first then it slides into the pipe.******
XXXX2 drop the rear 2 suspension bolts... get your hand up in there and push up while sliding them on... they are a pain, had the same thing happen to me this fall. PAtiEnTs... it will go!!! hehe
CaptCaper
- Jan 1, 2007
- Northern N.H.
- New Hampshire
I sprayed silicone on the inside pipe as well I think. slid right in. I think I bought a new one too so it wouldn't give any problems.
