Old Sticker Removal
Hair Dryer!!!! Slowly peel off the sticker. Remove the rest with Windex or Gue be gone depending on the leftover residue.
Peel off whatever you can, Spray a little Wd-40 and use a little elbow grease, should come right off
Heat both sides of the sticker, then peel what you can off, then use a automotive paint reducer to clean off the glue.
yeah, wd-40 works best.... used goo-gone (or similar) on a winshield a few years ago and it ruined it :o| ..... Let the wd-40 soak for 5-10 min and use your fingernail...repeat if necessary. Never leaves cratches or anything. ;)!
DO NOT use auto paint thinner on plastic. That's a BAD BAD idea. You'll be buying a new windshield if you do!
I do it all the time and have never had a problem with any of my stickers or leaving marks on my windshield after.
