bitburner
- Sep 10, 2014
- 2013 Nytro XTX 1.75
Anyone have this problem when one hand warmer works one day and then the next day it doesn't? Could it be a fuse? Or lose wire? Thanks
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
Your description is a little confusing. Does the hand warmer come and go( work one day then doesn't then works again) or did one just quit working all together?
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
Should like the grip is bad if it just quit.
bitburner
- Sep 10, 2014
It worked yesterday and it didn't work at all today. The other side and the thumb warmer are working fine.
radianguy
- Jan 1, 2007
Most likely the heating element on that side is burnt out.
bitburner
- Sep 10, 2014
Ok thanks guys.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
No codes?
boostednytro
Boondocker extraordinaire!!!!
- Feb 12, 2015
- 2011 yamaha nytro turbo xtx
I'm on my second one for the brake side if your sled is warrantied yet they will cover it I think the ecu has something to do with it
drunkenrich
Mine on the brake side went too yesterday, mine has the yamaheaters. The guy before me put them on. Can I just get one? Does it come with the grip?
boostednytro
- Feb 12, 2015
No grip just the heating element So you have to be careful taking them rivets out of the grip
drunkenrich
Rivets?
boostednytro
- Feb 12, 2015
Mine has two rivets in the grip you have to drill out to get the grip off what year is your nytro?
drunkenrich
bitburner
- Sep 10, 2014
Mine is a 13, it has the rivets. It didn't give any codes and runs perfect as always. Just did two 200 miles days back to back. Tipped it over a week ago and broke my hand guard off and now the hand warmer quit.
sledheadgeorge
My brake side warmer went as well while on a trip in northern Quebec last year. First dealer I found said he only had a heated grip from a Mountain Nytro but should be good. They installed it and away we went on our trip. I found that the grip from the Mountain Nytro is warmer than the stock throttle side heater for some reason. Haven't had any issues with it at all this year.
