Rx1 cowboy
Ok, i bought the skidont heated visor kit and ran power direct from the battery to the visor plug with a 10A inline fuse about 8 inches off the battery. Now where should the ground wire go to? There is only one red wire coming out of the visor plug outlet. Any help is greatly appreciated.
Joe
Joe
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
Ground to any metal on the chassis.
Rx1 cowboy
yes, i realize it has to be grounded but what am i grounding? Since there is only a power lead goint to the female visor plug what do i connect the grounded wire to?
megasunomi
is it the type of plug that has to be drilled through a piece of metal and you put a small flat nut on it to hold it on? if so thats your ground ..mounting ti to a metal object.
Rx1 cowboy
yes i grounded it to the frame, but what does the other end go to on the plug?
sorry if this sounds dumb
nhrxrider
I'm trying to understand what you mean. There should be 2 wires. One runs to the battery (I'm pretty sure Doo used red for this one), and there should be a 2nd, attached to a metal ring that is put over the back of the visor plug, held on by the mounting nut. That runs to ground.
I hate to tell you, but you paid around $20 for the same plug that you can get at Radio Shack for $2.50. At least the Doo plug has a cover though...the R.S. one doesn't.
Jim
Jim
Rx1 cowboy
thanks guys,
thats the way i wired it with the wire with the ring on it around the base of the plug and then grounded the other end to the frame. its the only way i could think of that made any sence to me
Joe
Joe
nhrxrider
Actually, I should have pointed out...because you are powering a simple heating coil, it really doesn't matter which wire goes where...unless you ever power something else off the same wire. I plan to power a helmet radio off the same wire, so I don't have to keep changing batteries, so it did mater when I installed mine.
Jim
Jim
