onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
- www.onestopperformance.com
Turbo charging your Yamaha Nytro, APEX, SKIDOO, ARCTIC CAT? YOU CAN TRUST your getting a system that has proven results. and CUSTOMER SERVICE to support you all the way with Remote access to help you tune.
Fuel your boost with One Stop Performance Engine Management System (EMS). With such features as COP ignition (Coil-on-plug) 2mb of data logging, 2-step, Multiple Fuel & Timing tables, map. OSP has been using and racing our cutting edge standalone kits we have set and broke more Speed and ET records than any other shop ever. we have developed 2 state of art fuel injection/ignition system. Check out
For videos of our standalone EFI and Turbo kits in action!
http://www.youtube.com/watch?v=HWUzoTf47co
http://www.youtube.com/watch?v=LhG37Wgw-JY
http://www.youtube.com/watch?v=kKwts5YVwf8
http://www.youtube.com/watch?v=a6CBM_xcGLs
http://www.youtube.com/watch?v=V74i9_OUR6s
Standalone kit includes OSP ECU, map sensor, data cable, wiring harness, air and coolant temp sensor, cam sensor, cam shaft mod, flywheel trigger, OSP high output coils, OSP 1000cc injectors, OSP aluminum hi-volume fuel rail, & EFI high Pressure Fuel Regulator.
Our standalone system that has mapping to 45 pounds of boost at sea level, and would not need to be tuned, BUT should you want to fine tune you will have that at your finger tips. EMS has built in data logging to fine tune, full timing control, as well as add on upgrades including, oil pressure, back pressure, fuel pressure, turbo RPM, jackshaft RPM, oil temp, Wide ban & more.
We have these kits available for Yamaha Nytro's, Ski-doo 1200's, and Yamaha Apex's SKI DOO ARCTIC CAT 2 and 4 stroke
we are Now close to having a KIT for the 1000cc and 1200cc D&D turbo 2 stroke cat
also we will Z1 turbo cat EFI ready soon
ski doo 1200 3 cylinder
Yamaha 1000 cc apex kit retail 4274.98
these kits come ready all you will need to do is tie in a few wires
this is the next step in making more power...
insane
Hey Jim. Whats the cost for an apex kit? What was your best run in NH on that full bodied Nytro w turbo? Thanks.
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
are you talking about at Epping last week?? best pass Jim W told me was 4.14 in 500 ft....
apex kits with everything you need, (call me if you have some things already it will be cheaper) 4200.00 that coils, injectors, fuel rail, wiring harness, sensors, 4 bar map, wide band,
full data logging, lots of expandability and easy to use
insane
Yeah I'm talking Epping. Did that have your stand alone? What was the mph in 500'? Didnt look like there was much shut down after the 500'. I think that nytro took all but a couple feet to get stopped before the trees!
- 10K
