loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
Have a 2013 Nytro MTX and after I start it it flashes op low and then it goes away after about 3 seconds. Only does it when cold. Once warmed up it is fine if I shut it off and start again. MY 09 nytro does not do this this. Anyone else seen this?
Alatalo
- Jan 11, 2005
Got something to do with the new safety function they added for 2013...?
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
Sounds like it. Talked to my dealer and said it was a new feature this year.
fxnytroxtx
Guest
Looks like my 09 xtx had the same safty feature then
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
What kind of safety feature are we talking about here?
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
Not sure on details. All I was told is that is brought over from the apex.
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
had the same problem on my 13 xtx this past weekend at the big horns. It did not display low op when I loaded it up at home
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
No worries, it's just the low oil pressure at start up. Once the oil circulates, the pressure shuts the signal off. My Apex does the same. Now, if it stays on, then you have an issue.
I remember when I had my Nytro, on extreme cold start ups, the warning light would come on and the low oil level would pop up on screen. Shortly thereafter, the light would go out. Oil level was fine. Sounds like a new safety feature on the Nytros.
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
thank you. not a warning I wanted to see 12 hours from home. but like you said it went away after 2-3 seconds
