Meadowbrook
- Dec 19, 2009
I was wondering if anyone has experience with the difference in a fully clipped track compared to a partially closed window track. Which one rolls better and which one provides better hyfax wear?j
Thanks!!javascript:emoticon('
')gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
open windows , add studs all good , we change sliders at 3000km
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
agreed....open window is better in every aspect(top speed,slider wear,rolling resistance,fuel economy,clip life)
Dan
Dan
Shivesy
I hope I'm not hijacking this thread by asking this question but when you guys are opening the closed windows are you adding any clips?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Just install some slp anti wear pads.Shivesy said:I hope I'm not hijacking this thread by asking this question but when you guys are opening the closed windows are you adding any clips?
SharkAttak
slp anti-wear pads work real good
shanksyamaha
are those available on slp website?? I'm gunna get a set I think.. do they decrease rolling resistance??
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
shanksyamaha said:are those available on slp website?? I'm gunna get a set I think.. do they decrease rolling resistance??
yes most guys with stock ripjunk track use this with much success....personally i pulled that track off before i rode the sled 5 feet,and dealer gave me a NEW predator in return for me to install....
I would never run a ripsaw....but some people do like them,just not for me.
either way,get the rubber away from slider to help with alot of issues....my guess is in a couple more yrs that horrible design flaw of closed windows will be a thing of the past,as they seem to be finally getting rid of them all.
Dan
Shivesy
Mighty said:Just install some slp anti wear pads.Shivesy said:I hope I'm not hijacking this thread by asking this question but when you guys are opening the closed windows are you adding any clips?
I already have SLP pads on all of my sleds. I was just curious if the were adding clips to the open windows thats all.
danq
Yes I added clips. the flat style, not the guide clip with the right angle leg.
I think open is better. seems to roll better and hyfax last better.
Kind of glad I did too, as at 10000 miles the original guide clips were worn thru and started to fall off. The newer clips I added kept me from having no clips. I just put new guide clips on to replace the worn out or missing ones....
schmeg
I am full clip with a 136 x 1.5 negligible top end reduction from the bigger paddle, and the clips have made the hyfax last longer
