NYTurbo
The BOP gasket works. I use the right stuff permatex in a aerosol can. One can does at least 10 oil tanks. I've done a bunch and never any issues
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I did mine year one cause I opened it up by accident. I used permatex right stuff as well.
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
2020 SIDEWINDER GT
next time due for oil change I'm putting on the BOP gasket and doing the hose loop...enough oil blowing out of the sled already.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Thanks all for the comments.
We had some great weather today (warm) so i sucked it up and tore it apart and re sealed with Permatex-Right Stuff. Better do it now while its easy, and not when its cold out. The earlier comment - "its not going to get better" kinda summed the situation up.
The gasket was real thin in the spot it was weeping. Again - this is on me, thought i put a nice bead down, but it pushed the sealant out when it was tightened. Will see how this new job holds up.
Will be interested to hear how BOP gasket holds up. If i have problems again, will give Travis a call.
MS
MS
Turbomax
- Oct 31, 2021
- Ottawa
- 2018 Yamaha Sidewinder
2014 Yamaha Viper
1983 Yamaha SRV 540
Old sleds:
1999 SRX 700
2003 Yamaha Viper SX 700
2008 Yamaha Phazer
I’ve got 6500 KM on my BOP gasket and no leaks at all (kept ROV). This year I removed the ROV.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
You can get the oil tank off without removing the muffler, I've done lots of them, I use the sealer Yamaha reminds. I don't use a gasket.I have the infamous oil leak as well. I did get BOP gasket to fix. Does anyone know if you can remove the cover and install the gasket without removing the muffler? Looks like you can, but bottom belly pan may be an issue. Thanks.
Woop Woop
Hi, what is the BOP gasket and where can I get it ?The BOP gasket works. I use the right stuff permatex in a aerosol can. One can does at least 10 oil tanks. I've done a bunch and never any issues
Turboflash
- Mar 18, 2019
- Southern MN
Woop Woop
Hi, so you spray both sides of the gasket? Can you give me the part # of that Right stuff Aerosol please.The BOP gasket works. I use the right stuff permatex in a aerosol can. One can does at least 10 oil tanks. I've done a bunch and never any issues
finnpowersports
- Nov 23, 2014
- Northern NY
- '23 SRX LE; '22 Assault 850; '22 Enduro 600R; '23 Rave RE
Perfect. Thank you!You can get the oil tank off without removing the muffler, I've done lots of them, I use the sealer Yamaha reminds. I don't use a gasket.
NYTurbo
Look up Permatex 26015. It doesn't spray, you pull the trigger and it applies a really nice bead on the surface. Works great with virtually no waste.Hi, so you spray both sides of the gasket? Can you give me the part # of that Right stuff Aerosol please.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I think NY is talking about this type of can..
This is what I use.
Clean, both matting surfaces WELL with brake clean ,a Lite wire brush, and wipe down with rubbing alcohol. Before applying sealant read manufacturers directions
NYTurbo
Yeah similar. Makes applying silicone futuristic. Lol
Woop Woop
Found it, thank you. So do you use this instead of the BOP gasket?Look up Permatex 26015. It doesn't spray, you pull the trigger and it applies a really nice bead on the surface. Works great with virtually no waste.
- 8K
