Ruckus
yo dude 12
these out for sale yet?
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
Yup I am sure Allen has them ready to go. At least last I talked to him they were ready
*Phazer Mod Airbox
Slightly improved low end HP!
3-4 HP gain on top end!
As quiet as stock so your buddies will never know!
Does not require any fuel injection mods!
$150 with air box exchange!
$225 without air box exchange!
For the exchange program simply send us the bottom portion of your air box and we will exchange it
for one of our Stealth MOD air boxes and return ship it the same day! 3-4 hp and as quiet as
***Please keep the air temp sensor and clamps when sending your air box to us!***
***There is no return or refund after receiving an air box. Yes the modification is simple, but we have spent the time and money to test and dyno this setup. You can easily lose 3-4 hp by altering the air box as well. This modification has been field tested & dyno proven. We will not accept returns or refund your money after you have seen the modifications and then decide you can modify your own.***
*Phazer Mod Airbox
xrrider
Just ordered my clutch kit from Allen today and asked him about the air box mod. He told me a good 5hp gain and he has some ready to go. ULMER RACING
yzman
i have bullseyes , i cant really notice any difference (Don't recommend it) , i think hp loss . But the problem is with my nitrous kit , i might lose some nitrous threw the bullseyes. So im gonna buy this mod and get rid of the bullseyes and test it out .
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
The airbox mods, both Ulmer & pod-type, flat out work.
Ulmer says about 5hp and that is true. Simply removing the airbox lid gains 5hp & this has been dyno'd @ Dynotech Research. Even Bullseyes gave about 3hp no problem.
So it's obvious the stock airbox/filter is restrictive in some manner.
I am mailing my airbox away to Ulmer for the Airbox mod exchange also. I researched this to no end & decided to go this route.
Caution: extra air intake does push up youe HP a bit but also leans you out a bit. Run premiun or better yet get a PC3 or PC5.
yam177
- Aug 14, 2008
- Shoreview MN
Pcv. Works great god proven map has been develiped as well. 3 degreez more timing also helps. Sorry for the apelling typing on a phone
09phazermichagan
ok the big question that noone has asked will this void my warranty?
Ruckus
09phazermichagan said:ok the big question that noone has asked will this void my warranty?
If something bad happens to your motor, buy another airbox and install it before bringing it to the dealer. If nothing happens don't sweat it.
yzman
X2 . My dealer tells me to remove anything modded and put stock back on . cause they gotta send pictures to yamaha to see if i can get it under warrenty.Ruckus said:09phazermichagan said:ok the big question that noone has asked will this void my warranty?
yam177 said:Much quicker 0-40. Faster response all over and a better pull on the top end. At muni on the Min Maintance road we ran 95-97 on the speedo where the stock sled pulled only 88-91
the Mod sled also had a PCV and an Excell exhuast
Ask Allen i think he was going to put together a kit. I just have to pull the Final fuel map out of the sled and get it over to him
What gearing do you use?
rotax454
I too would like to know? What gearing did you have in the sled when you reached 95-97 MPH? 99 on flat ice too? Damn.
yam177
- Aug 14, 2008
- Shoreview MN
Stock Gearing Clutches were both overdriven
