So I didn’t know this was an oil seal and the bearing behind it was lubricated by the engine oil... I took some Yamalube clear grease and squirt some pumps in with a grease needle... I did run it on and off for approximately five minutes at various rpms... what damage did I do if any??? its brand new oil and filter so I suppose I need to do a full oil change again... and pull the gear reduction cover where I deposited the grease... can I just pull that cover without draining the oil??? What happens if I don’t do the oil change??? Or pull the cover??? will the grease mix with the oil???
So here’s what I found!!! Most of the grease was retained in the cover...going to clean it up good and run it fo a weekend... I’ll keep a close eye on the oil and change it after that weekend
