Painting Shock Springs????????
sledheadgeorge
Ontario
Canada
Which one? I have 6
HAS ANY ONE EVER PAINTED THE SPRINGS ON THEIR SHOCKS? If so what is the best way to go?
I used Plasticoat in a rattle can. I got it at Lowes. It has a rubbery finish like the handle on tools. It has lasted 2 seasons with no chips. It is flexible. Worked great. It comes in several colors, black, blue, red, ? I used it on the springs and the arms on my M10.
thanks Indy, Anyone else try some thing other that powdercoat or plasticoat?
Powder coat will crack with time. My experience is that although powdercoating is an excellent way to finish a non-moving part (I have my truck rims powdercoated, for example), it doesn't last more than a season or two without scales flaking off in a coil-spring application.
IF elastomer agents can be added to keep the coating from becomg brittle once baked, it may work for you. I'd inquire with a powdercoater near you, if possible.
