1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Anyone run this with their NOS system or is it just for boosted sleds?
I will be running the PCIII, so I may not need this thing at all. Just thought I'l ask this curious question.
Thanks.....
-1CS
Thanks.....
-1CS
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
My buddy runs a knock box on his turbo....couldnt hurt with NOS but not sure if its needed,i believe all these sytems are rather safe with premium fuel for detonation....
Maybe if you go into a Higher HP SHOT this would be more of a benifit.
Probably a better thing to add with NOS would be a wideband A/F Gauge...which would help dial in your NOS to safe mixture levels.
JMO
Dan
JMO
Dan
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
NOS-DAN said:My buddy runs a knock box on his turbo....couldnt hurt with NOS but not sure if its needed,i believe all these sytems are rather safe with premium fuel for detonation....
JMO
Dan
Kool. Thanks for the info. I'll use the cash for that then.
thanks for the help.
-1CS
ejcamaro
Wideband is next on my list too.
Blown14psi
I like the idea of a tuner to be able to increase the rev limiter and to adjust the timing.
The wideband is also be a very important tool, but that is all it tells you is whether you are rich or lean it doesn't pinpoint the reason, so for tuning nitrous a fuel pressure gauge and nitrous pressure gauge are more important and they are a lot cheaper than a wideband. JMO.
For ultimate tuning it would be nice to have a wideband with the other two gauges and I plan on getting a wideband to run on my Supercharged Nitrous Mustang. Looking for 10's. YEEE HAAA!!!!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
I was thinking of a fuel pressure gauge, actually. I'm not concerned about the bottle pressure as I am getting the Holtzman system. From what I hear, I won't need it.
I think I will have everything covered with the PCIII, Fuel pressure, and Air/fuel. These will also reduce my costs when I decide to boost this sled.
Hopefully, in the future, a year or two, I plan to hook all the gauges and my NOS to a Turbo or Super. That aught to get me down the trail and accross the lake in a hurry. lol
-1CS
-1CS
Blown14psi
Can you use the Holtzman in boosted applications ? You may want to look into that if you haven't already before you lay down the dough it would sure suck to have to buy another or have a useless N2O kit. My buddy supercharged his Apex and he had the BOSS system with a controller over a $1000 kit that he can nolonger use.
P.S. anybody interested in a BOSS system witha tfi box?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Blown14psi said:Can you use the Holtzman in boosted applications ? You may want to look into that if you haven't already before you lay down the dough it would sure suck to have to buy another or have a useless N2O kit. My buddy supercharged his Apex and he had the BOSS system with a controller over a $1000 kit that he can nolonger use.
That would suck. Man. Perhaps I better do more digging than I have. I just "#*$&@ u me d " that any kit would work. Darn it. I thought I had a game plan here. Now I have to start all over. lol
-1CS
Black 1000
Why can't he use the Boss with the SC??
Blown14psi
Because the APEX/Attack BOSS is a dry kit with an EFI controller and the supercharger somes with it's own controller they aren't compatible. If you use the old style BOSS without the controller and spray the supercharger intake then I suppose it would work.
TurboJamie
I can't see why the knock box wouldn't detect knock with a motor on spray. When I used to spray my talon if it detected knock the knock sensor would pull timing from the N20 so I am sure it would work on your sled. Knock from deto is knock doesn't matter if its boosted or sprayed.
Black 1000
Ok now I understand. I have the Boss on my 03 and I couldn't see why it wouldn't work
motohd66
i have a boss system on my apex. all you have to do is get the box reprogramed for the supercharger. i dont understand why they didnt tell your buddy that. if u have any questions about the tfi box just call dobeck performance cuz they actually make them but boss each vendor puts their nitrous, turbo, or supercharger program in them.
