Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
I'm very interested in this as well! I'm not a clutch tuner, so calibrating the PB to match my existing Yami clutch would be my only concern.
wowchad
- Feb 21, 2014
- Milwaukee'ish, WI
- www.tewco.com
- 2005 F6 - 2009 MXZ 800R - 2010 Nytro - 2015 ACE - 2016 MXZ 1200X
- Milwaukee'ish, WI
- http://usa.cvtech-aab.com
If it's stock then you're all set to drop one in and go, no additional calibration needed.
If you're modified then I'll include a stiffer spring and you get extra weights to play around with. The best part is how simple they are TO modify, there's nothing to them!
Pull off your clutch bolt, take off the 1-7/16 PB80 nut and all you need is a big flathead screwdriver to unscrew the retainer cap holding in the weight discs.
(If you do decide to change a spring that's only 3 6mm hex-cap screws)
You can see the weight blocks in the picture. One front-side, one back-side and one with the retainer unscrewed and weights pulled out.
04mx
- Oct 20, 2015
- canada
- Yamaha
I have a few questions.
1 does it have the nasty rattle of the stock clutch ?
2 does it or can it have overdrive ?
3 does it come with a spring ? if so what rpm does engage ?
thank you
thank you
shadow44
Wowchad, sounds like you're selling the product and if that's the case you need to go through proper channels which is site owner Mr Sled. This thread will get taken down if that's the case...just giving a heads up.
04mx
- Oct 20, 2015
- canada
- Yamaha
wowchad just pm me then !
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
According to his post under general discussion he runs the show at cvtech...
Wowchad contact Mr Sled so you can keep giving info to people who are interested in your product...
This thread is now locked: You need to contact us as soon as possible or this thread will be removed. Its under review by our staff for advertising without pay or non paying permissions. Please contact us or this thread will be removed and your account suspended.
- Status
