BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Has anyone verified performance gains of a PC Ignition module on a Nytro? Either Dyno testing and/or controlled field testing.
thetruck454
When I talked to Allen from Ulmer Racing he said on the nytro there isn't much to be gained from the ignition controller. He runs them on the boosted sleds but I'm assuming that is to retard the timing for boost.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
No gain in HP on the engine dyno, but they will gain some top end in the field. The gain is at 9,000+ rpm where the stock timing starts to retard. Not much effect for the average trail guy.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Yep, if you are trying to get more top end, that is where it works...
BADSLED
- May 13, 2004
- Syracuse, NY
Srxspec said:No gain in HP on the engine dyno, but they will gain some top end in the field. The gain is at 9,000+ rpm where the stock timing starts to retard. Not much effect for the average trail guy.
Would I need to run premium fuel with the Ignition module?
SledFreak
- Feb 7, 2005
- Ontario. Canada
yes...
