PC III for 2006 Apex mapping
bigdog_mike
Fraser, MI
Have just purchased PC III for 2006 Apex motor that I have installed in a Polaris RZR and I need to setup the mapping for it as the stock setting is too lean for warm summer temps it reads 14.7 at idiel the gets leaner as the rpms increase at mid throttle iit's reads 15.2 then at full throttle it runs 15.7 on the air/fuel meter which is way too lean and will harm the motor in no time. Need to figure out how program the mapping to richen the low/mid/high range using the PC III and the manual says during the first five seconds to depress all 3 buttons then to increase the fuel press either of the 3 different range buttons or press and hold buttons to decrease the fuel settings...tried this but it doesn't increase or decrease the fuel setting... what am I doing wrong? Any help out there?
bigdog_mike said:
Have just purchased PC III for 2006 Apex motor that I have installed in a Polaris RZR and I need to setup the mapping for it as the stock setting is too lean for warm summer temps it reads 14.7 at idiel the gets leaner as the rpms increase at mid throttle iit's reads 15.2 then at full throttle it runs 15.7 on the air/fuel meter which is way too lean and will harm the motor in no time. Need to figure out how program the mapping to richen the low/mid/high range using the PC III and theanual says during the first five seconds to depress all 3 buttons then to increase the fuel press either of the 3 different range buttons or press and hold buttons to decrease the fuel settings...tried this but it doesn't increase or decrease the fuel setting... what am I doing wrong? Any help out there?
I would contact Ulmer Racing and speak with Allen on this. He may have something for the PCIII. He is a dealer for the Power Commanders.
bigdog_mike said:
will call Ulmer as I tried email but still waiting for reply
If you dont get thru or he dont get back to you in a few days, let me know and I will see what I can scrape up.
