mach9
I like the sound of this AutoMap feature.
With a bung / port welded in we could keep adding mods here and there and re-map perfectly for each change and or daily Hi/Low pressure or elevation changes.
Does the PC5 come with the O2 sensor?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The Autotune is not as easy as it sounds. You set the Air/Fuel ratio you would like to see. The PC5 then saves the amount of change it takes to make the Air/Fuel ratio. You must hook a laptop up to the PC5 to say Yes or No to the changes made by the Autotune feature. It does not just continually automatically adjust your base program, you must tell it Yes or No to accept or deny the changes.
You must purchase both the PC5 and Autotune if you want the O2 feature.
mach9
Srxspec said:The Autotune is not as easy as it sounds. You set the Air/Fuel ratio you would like to see. The PC5 then saves the amount of change it takes to make the Air/Fuel ratio. You must hook a laptop up to the PC5 to say Yes or No to the changes made by the Autotune feature. It does not just continually automatically adjust your base program, you must tell it Yes or No to accept or deny the changes.
Thanks for the info.
I still like the idea, of this Autotune.
I use a mini laptop.
Making several baseline maps and tweaking might be fun.
(or frustrating !!)
yamahaboy701
If you are looking for a PCV, I have one for sale in the classified section. I really liked it on my sled but have bigger plans.
