bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
I have a PCV with Wideband2, Ignition Controller and POD display from PUSH Turbo on my 09 Nytro. Everything seems to be working properly but I am not getting any data from the Throttle Position Sensor. The monitor on the POD and data logs all show 100%. Wondering 3 things:
1. If they system isn't reading TPS, will this cause trouble with mapping?
2. How can I get it to read the TPS?
3. If I adjust fuel trims on the POD, do those changes get stored on the PCV, or do the trims only get applied when the POD is connected? I had removed the POD and went for a ride and the sled didn't seem to run as well as it did when the POD was connected.
Thanks!
Thanks!
