Phazer belts
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
8GK-1764-10(reverse Update)
8GS-17641-00
What is the specs on the 8GK belt?
Is the 8GS even available anymore?
Somehow dealer stuck me with a 8GK belt and it really messed up my clutching.I dont even have reverse.
Not sure what you are looking for here. But, the OEM spec for the 08 Nytro is below. Are the part numbers you listed OEM? If not, you are kind of on your own when you buy non-OEM belts. But to get a match, here is a spec for the '08.
V-belt:
Part number/Manufacturer 8DN-17641-01/MITSUBOSHI
Circumference 1,129 ~ 1,137 mm (44.4 ~ 44.8 in)
Maximum Width 34.1 mm (1.34 in)
Minimum Width 32.5 mm (1.28 in)
Those are OEM #'s for the Phazer.Here is specs for 8GS but it seems the 8GK superceeds the 8GS.I want to find what the size difference is.
