YAMMIEGOD3:16
- Apr 14, 2005
ANY OF YOU GUYS DONE ANY GRASS RACING WITH YOUR PHAZER, WHAT YA USE FOR GEARING. AND WHERE YA FIND YOUR GEARS. 3:16 (yammie tony)
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Stock gearing is 18/41 on the standard Phazer and FX/RTX models. The GT Phazer models came with 20/41. The only other top gear to lower the gearing available for them is a 17 top tooth from the Mountain/MTX models. The only other bottom gear availble for them is a 45 bottom gear from the Venture Lite model. It has a 80 link chain standard, if you went to the 45 bottom gear then you need a 82 link.
