Phazer shut down.
Bento
Michigan
2009 Phazer RTX, 1000 miles, new this fall. My buddies Phazer suddenly shut down at idle. Sled would not restart at first but was eventually able to get it running. It is only running on one cylinder. Could this be a fouled plug? Has anyone had this similar problem occur? He was riding groomed trail and came to a stop when the sled sut off.
I highly doubt a phazer would run on only one cylinder - it would be nearly impossible to keep it running - and it would likely fire an engine code - how did you determine that this was happening?
If it is somehow only running on one cylinder, change the spark plugs, one is probably cold fouled.
Mark
