Phazer Starter wont engage?? Wiring problems?
quadtrac
Glencoe, Mn
Last week I completely tore apart my 07 FX Phazer to put in a left hand side frame casting. I had the engine out as well as the entire wiring harness. After I had everything put together and the wiring all routed and plugged back in, the starter will run but doesn't engage and turn the engine over. Also when I first tried to start the sled I seen smoke come out of yellow plastic piece that almost looked like a fuse by the oil tank. I then untapped the harness and seen that one of those little black wires was kinda melted that goes into the main harness. What did I do wrong? I am really confused on this one!
i have never had a starting issue with my phazer so this is just from information i read on here. apparently the starters are always engaged. you problem might be that the bolts came loose and "de-indexed" i think they call it. there is a fix that involves removing one bolt at a time and locktiting it while making sure a green line on the starter is lined with with a line on the engine. please correct me if i am wrong.
That yellow piece of plastic by the tank needs an updated part. There is a service bulletin S2009-008 that explains what needs to be done. Your dealer should cover the work free of charge.
i've also heard of this. this melted yellow piece i think causes alot of issues people are running into.
