Having problems with TORS on a Phazer, checked to make sure that the cable isn't binding and that with bars turned from full lock to lock that the cable isn't being pulled, but still can't get the TORS to work properly, is it possible that the TORS sensor is bad? Any thing else that I need to look at?
xt_gt
maybe check the throttle lever for too much play? or the little tab sticking.
even though it's not binding maybe try rotating the throttle up or down on the bars and see what happens.
bigdave
- Dec 18, 2003
- sylvan lake, Michigan
- 14 Viper LTX SE, 14 Viper RTX SE , 08 FX Nytro , 07 FX Phazer, SOON 2017 Sidewinder LTX LE Blue
where is the little tab that could stick??
xt_gt
Sorry for the confusion. I was thinking there was a tab behind the lever. What it was is the cable itself. I just went out to check.
NO tab, my mistake.
NO tab, my mistake.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
How much throttle cable free play do you have?
bigdave
- Dec 18, 2003
I bet I have 5 mm or so should it be run tight ??
bigdave
- Dec 18, 2003
the sled would not even come off the trailer yesterday pulling forward no crank of the handle bars
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
I'm unsure of how to adjust. I'll snap some photos of my manual and hopefully it will help you.
Do you have a code???
- Nov 1, 2009
- 2009 Phazer RTX
I had posted a step by step a couple years back, I'll try and dig it up.
bigdave
- Dec 18, 2003
I don't remember a code but I was so frustrated I may have just not looked ! ill check tonight if there is a code, maybe I try the TORS override to see if it moves.
bigdave
- Dec 18, 2003
thanks a step by step may help me out thanks
- Nov 1, 2009
- 2009 Phazer RTX
http://www.ty4stroke.com/threads/throttle-free-play-adjustment.109756/
But my post is missing... working on fixing that lol
bigdave
- Dec 18, 2003
I just noticed that
Ill check it in a while.
thank you a ton !!!! everybody !!
Dave, I have the Phazer service manual on PDF format that I will put on a thumb drive
ATV PRO #11
- Jan 22, 2011
