Phazer Turbocharged Oil Drain
slobra96
I was wondering where you guys drain you oil for your turbos on your 2007+ phazers. The engine is no longer in a snowmobile and the turbo will be mounted about level with the exhaust ports. I am thinking of just gravity draining it back into the oil can, but wanted to see what you guys do first. Thanks
mine goes into the can. pulled the can off, welded a -10 line on it. not sure if you can see it in this pic but its above the battery. let me know if you need any other help or maybe want a kit!!
<a href="http://s1228.photobucket.com/albums/ee459/ride784/2007%20Phazer%20Turbo/?action=view&amp;current=IMAG0462.jpg" target="_blank"><img src="http://i1228.photobucket.com/albums/ee459/ride784/2007%20Phazer%20Turbo/IMAG0462.jpg" border="0" alt="Photobucket"></a>
^Thanks, does that kit use a scavenge pump to drain the turbo? and where do you tap off the engine to get the oil, Im guessing at the pressure switch?
its a kit that was done by my buddy and i. he owns a fab shop and does awesome work. i havent needed a scavenge pump but i also do trail riding.
Where do you get take your oil from for the oil feed line, and do you use a inline oil filter at all?
Also are you using larger injectors for this kit?
oil comes from the sender. i just use the stock oil filter, nothing inline. yes on the larger than stock injectors. can be bought off this website form an advertiser. GNS is the company. im still working on the maping. i also used a 1:1 fuel pressure regulator. if your intrested in my manifold pm me for more pics / prices.
The MC Express kit on mine drains down to the engine. The kit comes with a fitting that you put in the plug on the right side of the engine and it gravity drains from the turbo. The oil supply comes from an adapter that goes on underneath the oil filter then the oil filter screws on to the face of it.
Do you have any pics of the drain, I would like to see where it drains to. Im just wonder where exactly it is. Thanks
