go200mph
Great pic.
snowy1
my 2003 rx1 with light wieght parts and turbo was 610 wet, looks like I have that arctic cat beat, if its really 618.
BBM
- Oct 6, 2004
That weight could be accurate. Gas weighs around 6lbs. per gallon so a 10 gallon tank would weigh 60lbs. and the coolant and oil would use up the other 10lbs.. So 482lbs dry sounds right.
hi guys and gals
well I was @ the shop and just had the mountain lite full of fuel, oil, and coolant and tiped the scale @
531 lbs wet
531 lbs wet
jp@weknowsnow
- Jul 19, 2006
- colorado mountains
- weknowsnow.com
nice. its great to have a confirmed source. thanks!
531lbs is pretty damn good!!
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
on second thought, that must mean the mtn lite is less then 514lbs dry?
mtn lite base = 514lbs
~6lbs X 8 gallons = 48lbs
other fluids = 5lbs? or more
~570lbs? am i missing something? i so want to believe. bahahaha
but srxspecs FX comes in at 505lbs so this could be right on for the mtn lite.???
http://ty4stroke.com/viewtopic.php?t=30 ... s&start=15
BBM
- Oct 6, 2004
Gas is lighter now, being that it is oxygenated it weighs 2lbs. less per gallon. Also, synthetic oil is lighter. This should lighten things up buy 18-20lbs.
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
well my cert of origin from yamaha came today and it listed the phazer's shipping weight at 507lbs..
must be w/ crate?
awesome...why does the site say 514lbs????
must be w/ crate?
errol
- May 24, 2003
- Quebec, QC
- 2018 SW B-TX LE 50th
So a Phazer Mtn Lite (531) weighs less than a Phazer GT (553) both fully wet ???
phazer
Dont know wut to tell ya
Thats wut are scale says.
I still think that is kinda heavy for a 500cc but yamaha is always a bit heavier than the comp cause they over develop for strength.
I would rather have a 30lb heavier sled that can take abuse than a lite weight one that breakes every ride or first tree well or roll over.
BBM
- Oct 6, 2004
JP
You should see if your dealer has a copy of the certificate of Origin, that will show the weight of the sled by itself.
jp@weknowsnow
- Jul 19, 2006
- weknowsnow.com
BBM- I have my cert of origin and it says from yamaha that the shipping weight is 507lbs... that must include crate?
Yamahnator
Either your scale is off or something else is up. Full wet means with a full tank of gas.
Yellowknife
- Jan 25, 2004
- Yellowknife, NT, Canada
- www.youtube.com
Are there no mags out there yet with these specs?
swamps
- Sep 12, 2006
devin said:hi guys and gals
531 lbs wet
If 531 lbs WET that would be to good to be true
I hope your right
