That weight could be accurate. Gas weighs around 6lbs. per gallon so a 10 gallon tank would weigh 60lbs. and the coolant and oil would use up the other 10lbs.. So 482lbs dry sounds right.
Gas is lighter now, being that it is oxygenated it weighs 2lbs. less per gallon. Also, synthetic oil is lighter. This should lighten things up buy 18-20lbs.
