TheMogulMogul
whupperofwhoops
My Larson Racing 4 wheet kit arrived and I’m very impressed. It looks strong and very well machined. I really like how the axle is keyed into the outer hub. I’ll update this thread with install photos later when I install it.
Kit contents. Axle is 1” thick in middle. Four 8” wheels.
NYTurbo
Price ?
TheMogulMogul
whupperofwhoops
$350
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
That is one bad-azz 4wheel kit right there....
Not cheap though, but should last long long time. I like how it adjusts too.
Dan
Dan
TheMogulMogul
whupperofwhoops
Yeah I wanted to try it out and I’m impressed. Unsure if it’s worth the extra $$ over the J&T Stealth kit though, which I was originally going to buy before I found the Larson kit. I actually prefer the solid oem wheels because they will be cheap to replace and readily available anywhere when the rubber tears. Also I worry about the possibility of chunks of ice or rocks getting inside the open spoke wheels, even though they look nicer. Interesting side note, Larson says the 7.5” for 129 and 8” for 137 is optimal and going bigger they noticed uneven wear pockets on the sliders. Dunno what size wheel Stealth kit you have but your slider wear looks great in that other new sidewinder thread.
Pstn head
Definitely worth the cost imo... Having the axle go through the rails alone is worth it. That's what was my deciding factor.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yeah I read that too.....I will only say on my 129, the larger stealth wheel(7.5") has done zero harm to slide life, as a matter of fact i have never seen sliders with 1450 crappy snow miles on them, where they look like a new sled still....no wear at all that I can see, its crazy. But sure is nice to know I likely will never need to change sliders. This was all with inner idlers chunking off too!Yeah I wanted to try it out and I’m impressed. Unsure if it’s worth the extra $$ over the J&T Stealth kit though, which I was originally going to buy before I found the Larson kit. I actually prefer the solid oem wheels because they will be cheap to replace and readily available anywhere when the rubber tears. Also I worry about the possibility of chunks of ice or rocks getting inside the open spoke wheels, even though they look nicer. Interesting side note, Larson says the 7.5” for 129 and 8” for 137 is optimal and going bigger they noticed uneven wear pockets on the sliders. Dunno what size wheel Stealth kit you have but your slider wear looks great in that other new sidewinder thread.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I agree, that axle design is kick butt....and I like what he does with adjusters being moved outward, so much better setup. Pricey but worth it for sure.Definitely worth the cost imo... Having the axle go through the rails alone is worth it. That's what was my deciding factor.
Dan
Over 12000mi on mine. Greased the bearings twice. Thats it.
TheMogulMogul
whupperofwhoops
Dan
Just read it again and I remembered it wrong, he said 7.125 (not 7.5) was optimal for 129. Well then maybe it is 8.4 for 137 that can cause wear pockets, but for sure the 7.5 are working great for you!
Byam
I love the fact that they don't reuses these cheap part...Over 12000mi on mine. Greased the bearings twice. Thats it.
Yes those are junk and adjuster on outside is so much easier to get at!I love the fact that they don't reuses these cheap part...
Wont break this! And I run my track tighter than spec.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
This alone is worth the extra cost IMO, getting rid of junk adjuster parts for the most part.Wont break this! And I run my track tighter than spec.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I have been extra cautious to torque down the AXLE so there is least amount of pressure on the adjuster junk. And I do run my 129 ultra tight too, lucky so far but only 1450mi on mine so far.I love the fact that they don't reuses these cheap part...
Dan
