dylanjen9
I just went to get my 07 vector from storage and when I turn the key it dosent do anything no clicks or sounds. Yes the kill switch is up. I put the battery tender on it a few days ago and it says it is fully charged. What are a few things I should check first? What is the trick to make the lights come on without it running so I can make sure the battery is working?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I would pull the battery and have it checked. Do you have a voltmeter? A fully charged battery should read something like 12.6v. Somebody correct me if I'm wrong.
Your battery tender likely won't get a charge into the battery if it's fully discharged. It may giver you a full charge reading even if the battery is discharged.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Hookup a set of jumper cables to a car to see if it will come on. But I would check the fuse and wires for a bad wire.
copo427ss
Defianatly check the battery voltage with a volt meter to varify battery voltage. Now these batteries like to sometimes short a cell out. You'll get a good voltage reading but the amperage won't be there. Check the fuse at the solenoid. One is a spare the other Is main power to the entire machine.
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
Same thing happened to my phazer a few years ago on a tripit worked fine one day and the next nothing it wound up being the starter. So if u got life in the battery and the fuses are good I would have the starter checked out.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Check the voltage even if the charger says its full. also try boosting it.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
you could also find the batery cables are loose mine seem to come loose every year. have you inspected the batery yet?
dylanjen9
I am going to try to jumpstart it tonight.Will let you know what happens.
dylanjen9
When I jumped the sled it started and ran but when I took jumper cables off the gauges would not work but it stayed running. When I shut it off it would not do anything again. So I guess It needs a new battery right?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
dylanjen9 said:When I jumped the sled it started and ran but when I took jumper cables off the gauges would not work but it stayed running. When I shut it off it would not do anything again. So I guess It needs a new battery right?
Yes time for a new one.
YamRaider
I would try a new battery first and hopefully with a new battery the gauges start working again. The stator probably couldn't keep up running the lights, engine and accessories if the battery wasn't holding any charge at all.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Same thing with my '07 with the original battery. Battery worked fine last season and this fall it was totally shot. Not even my Optimate 4 could bring it back to life.
5 years is a good run for a sled battery. I was planning on replacing mine anyway just for peace of mind. I went with an Odyssey battery since I have had one in my Sea Doo for six seasons.
