rage man
hey guys just starting to tune up the rage for the winter and i wanted to up date the front shocke on my 05 rage and im just cant decide between the Öhlins "Piggy Back" Shock or the gytr "piggy back" Shock just wanted to know your opnion because the Öhlins is 200 bucks more a shock and i dont know if its worth it thanks
polaris the way out YAMAHA THE WAY BACK !
DELTABOX
The GYT-R shocks are very good. I am very impressed with the ones on the Apex GT. Very easy to adjust and you can feel a difference. They have rebound and compression damping and should not need a rebuild for a number of years. The Ohlins are very trick and have a great bling factor and if your are racing or a super hard rider they might be slightly more adjustable in smaller increments. I would suggest the GYT-R unless you want the ultra cool factor.
AKrider
I had the same decision last winter and went GYT-R because all the parts are available in the US. There are some parts that can only be ordered from Sweden for the Ohlins. The other thing, if I emember correctly, is that the Ohlins only had compression adjustment while the GYT-R's have both rebound and compression.
The ride of the GYT-R's are mush, much better and controllable than the stock Soqi's I had.
rage man
thanks guys
