GP292
- Mar 5, 2007
- Southern-Tier New York State
- 2016 RS Venture TF
I have a pair of pilot 6.9 skis that I would like to mount on my 2016 rs venture TF. I don't see any way they could fit he Yamaha spindles. Can somebody please help.
radianguy
- Jan 1, 2007
You need the rubber mount from a skidoo zx chassis.
I had this set up on both of my sleds, took them off of the NYTRO because they pushed too much in the corners.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Your Venture is power steering right? I had Pilot's on my 2012 Apex when new. Yes you need the Skidoo ZX rubbers, but you'll need to trim them because the power steering sleds have an offset spindle.I have a pair of pilot 6.9 skis that I would like to mount on my 2016 rs venture TF. I don't see any way they could fit he Yamaha spindles. Can somebody please help.
GP292
- Mar 5, 2007
Yes the venture has power steering. I have a pair of zx rubbers and want to know where you trim them. Thanks.
Redbeard
- Oct 14, 2011
- IN
The older, non power steering Yamaha spindles and the Skidoo ZX rubbers are a perfect fit; like they were made for each other. The newer power steering spindles have an offset that sets the ski 15mm farther back. Also, the part of the spindle that sits in the ski saddle is shaped different. A simple 3/4" trim will allow the rubber to work. I used Pilot 5.7's on my Apex at first, but did not care for how the sled handled; I never tried the 6.9's on this sled. A friend of mine has 5.7's on his 2011 Apex for 5 years and likes it.Yes the venture has power steering. I have a pair of zx rubbers and want to know where you trim them. Thanks.
I have used Pilot 6.9's on my 2008 Vector since the winter of 2011. I removed a ski and took pictures to show you the difference in spindles and how the rubber needs trimmed. Maybe you'll find a cleaner way to trim them without having to cut away so much material?? FYI, unless there has been changes, your Venture spindle should be the same as my 2012 Apex.
I hope this helps!
GP292
- Mar 5, 2007
I hope this helps!
View attachment 111877 View attachment 111878 View attachment 111879 View attachment 111880 View attachment 111881 View attachment 111882 View attachment 111883 View attachment 111884
Thanks for the info and pictures. I will give it a try.
