grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
The Yamaha ski loops are wider at the mounting points so a little bit of triming and grinding is required.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I've had some trail time on the new pilot skis and revalved shocks. The trail conditions have been mostly hard pack and icy but I've found a few I'd consider good for testing my setup. My first time out I was total disappointed but after a few adjustments, several miles and a few more adjustments I'm beginning to like what I have. The revalved fox floats and rear shocks didn't make as much of a difference as I was hoping for but the Pilots definitely made it corner much better which is what I was looking for. I was running OEM skis with stud boy deuce bars which eliminated the darting but didn't rail the corners like I wanted. I now can rail the corners with almost no inside ski lift and effortless steering. I'm having a hard time determining if the shocks added to the improved handling because I did both installs at the same time. I was hoping to get a little plusher ride out of the revalving but if it only contributed to the handle improvement I'll take it.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
I had my rear shocks done by pioneer and Im not that impressed either, more bottoming resistance on the big holes but not very plush on the stutters.
enticeraised
grizztracks said:The Yamaha ski loops are wider at the mounting points so a little bit of triming and grinding is required.
Nice vice
- 22K
- 12K
- 9K
