Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Big boy spring will be off little help in preventing the shock from blowing. You minmally need the new seal head from Ohlins and I highly recommend the revalve job.
Alatalo
- Jan 11, 2005
According to a local Yamaha rep, failures of the european shocks seem to be very rare.Reaper said:Big boy spring will be off little help in preventing the shock from blowing. You minmally need the new seal head from Ohlins and I highly recommend the revalve job.
I do not know if this is because of the setup difference (stiffer spring and damping) or because of something else (like not as many units sold).
I would not be too sure about the setup not affecting the seal blowing...
Anyway, when you get a revalve, ask for the updated seal head with Ohlins part number 5129-12 (the old one was 5129-02).
Reaper
- Nov 10, 2005
I have had shocked revalved and new seal head installed. Revalve is closer to European spec. The shcok works great now !
schmeg
Bruce did mine before the season. I ride as hard as I want with no bottoming issues to speak of. The suspension is actually a little on the firm side now. Best money spent on this sled. Except for the wear pads.
tkuss
Do you have the big boy spring or not. I weight 180 with the KYB shock and want to revalve but dont know what I should do with the spring.schmeg said:Bruce did mine before the season. I ride as hard as I want with no bottoming issues to speak of. The suspension is actually a little on the firm side now. Best money spent on this sled. Except for the wear pads.
GREGSER1
Hi
New to the site and to yamaha. Just got a new apex er. I was looking for some info on a revalve w/ new spring for my sled. Put 400 miles on the stock shock and it did alright, but bottomed out on some of the big stuff that i thought it should of handled. Any info would be great.
Reaper
- Nov 10, 2005
I am 180lbs and run the stock spring with PP valving and it wortks great !
