phatkid
yamadog....
I have a 7 inch rsi on mine with there pivot post installed how does that apex cover fit on there??
I had to drill out the threads on my stock steering post to mount my pivot post and run the bolts from the bottom -up through the pivot adapter
think the apex cover would still work on my application???
Jammie
Jammie
yeah then youve got a problem. I drilled out the riser and sent the bolts down through to the original threads on the shaft. I doubt that you have enough room to work the bolts in. The ring is 2 piece and the bottom 1/3 goes on and is sandwiched by the riser base if it is not a stock yammi riser you'll also have to machine the base to accept the ring.
Here is a close up you may be able to stick the bolts in place with plummbers putty or gum set everything in place and then tighten with a flat wrench. I used door edge molding from PEP Boys around the body work lip to give it a more finished look.
If you double click on the pick you should be able to enlarge it
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
Heres mine on my 04 Warrior with the Lake Effect Snow Riser. My pivot has the cutout for the Apex Ring easy install if you have all the right parts.
phatkid
damn that looks super clean and finished properly...
Nice job guys ill send out a pic of mine to show u what i have
Jammie
Jammie
Snowmofrk13
well i got a 6 inch riser with carben fiber race bar with hooks and so on so i am happy to say my sled looks awsome will get some pics up
2004rxwarrior
04rxw10, would you be able to post a few more pictures of the cover installed? Any steps, instructions or advice you could provide would be greatly appreciated.
04rxw10
- Jan 28, 2008
Will send you a PM so we dont hijack this thread
