piviot riser and cables
yamadog....
I have a 7 inch rsi on mine with there pivot post installed how does that apex cover fit on there??
I had to drill out the threads on my stock steering post to mount my pivot post and run the bolts from the bottom -up through the pivot adapter
think the apex cover would still work on my application???
Jammie
yeah then youve got a problem. I drilled out the riser and sent the bolts down through to the original threads on the shaft. I doubt that you have enough room to work the bolts in. The ring is 2 piece and the bottom 1/3 goes on and is sandwiched by the riser base if it is not a stock yammi riser you'll also have to machine the base to accept the ring.
Here is a close up you may be able to stick the bolts in place with plummbers putty or gum set everything in place and then tighten with a flat wrench. I used door edge molding from PEP Boys around the body work lip to give it a more finished look.
If you double click on the pick you should be able to enlarge it
damn that looks super clean and finished properly...
Nice job guys ill send out a pic of mine to show u what i have
Jammie
04rxw10, would you be able to post a few more pictures of the cover installed? Any steps, instructions or advice you could provide would be greatly appreciated.
