pivot arm mods
06RTXRider
Cicero, NY
For those of you who are reinforcing your front pivot arms, are you reinforcing the updated pivot arm or the stock 06' arm that had very few gussets. I replaced my original with the updated "reinforced" arm but am worried it will crack again. i've also broken the rear arm and have 2 small cracks in the rail where the reinfocments bolt on. Trying to get this back together before the snow flies. I'm not sure what to do with the rails. One side had been cracked for a while and not sure if it will getany worse or not.
