PLEASE HELP! back firing when handle bars are turned left
MOTOWN SPEEDFREEK
Oxford, Mi.
went up riding, when turn handle bars left ,back fires. took pad off checked pluge when wiggled white plig of thorrtle side would go away. is this a throttle sensor,do you think putting electrical greese in there and reconnecting will fix problem. Has any body had this problem.PLEASE HELP!!! ;)!
Just a hunch but I'd say your throttle cable is too tight causing the TORS to activate. Loosen the cable at carbs a bit and see if that helps.
Did you recently put in some handlebar risers? If so, you may have pulled the wires too tight, in particular when turning hard.
What they all said!
Hpe you get 'er figured out.
;)! THANKS TY members for your help. It was lose connection,plug going to right side and lose throttle cable, when turned handlebars,it turned. :rocks:
