Vmax540
All the rubber pieces go on airbox.Straps in front hold box down.Other two go in front left and right side under box and fill gap to subframe.Bleeder is on right side by coolant bottle.Little black rubber cap.Check manual for procedure.
marpolsdofer
No I think the 2 rubber straps are for the fuel tank cover (not sure if the 07 had them but the 08-up did). They bring the left and right side covers together. The box is not held down with anything other then being attached to throttle bodies. The top v cover has a strap but is attached to it and then hooked to the frame.
The big rubber parts are right.
Yes thanks Marp.Mine does have a rubber strap at front of airbox holding it down though and also one for colored trim piece on top box.
