geez150
While doing chain case maintenance I noticed a two prong plug that looks similar to a battery charger quick connect. It wasn't plugged into anything, question is should it be and if not any idea what it's for?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
accessory/ power tap... on and off with the key
geez150
Thanks. Just seems like there should be a cap or something on itaccessory/ power tap... on and off with the key
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
There usually is? Is it black?
geez150
Yes. There is two types of these plugs over in that area along with the other bigger multi wire plugs. One set of these two prong plugs are mated together and the plug I am referring to is just there uncapped and not mated together with anything. Unless at one time it did have a cap and fell off, no big deal I will just tape it up. Just wanted to make sure that it wasn't supposed to be mated to another set of wires.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I think what you are referring to is the SAE connector for the helmet shield heater, if you choose to add one. I think that is what it’s called. There is a post out there concerning that, nice write up with pics, which made my heated shield hookup very easy.
Pretty neat, just plug and play. No more having to bug in to wiring harness for simple heated shield 12vdc hookup.
Not sure if it was capped prior. Will have to take a peek on mine, maybe tomorrow when I pull the sled in to my garage for the start of pre ride maintenance.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yes...also called a trucker plug Ive heard...fyi I have a three way splitter there...heated shield ....wide band o2...and led light hookup all running off that..
ShootToThrill
Is it a key on power or engine running power ?yes...also called a trucker plug Ive heard...fyi I have a three way splitter there...heated shield ....wide band o2...and led light hookup all running off that..
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Hey SJ, where did you buy that 3 way splitter?, sounds interesting.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
That is powered by a 20 amp fuse. It also powers the back up alarm, tail light and the dash pod.
That is what I noticed anyways when I inadvertently blew it last year.
May be more, would have to check the wiring schematic to be sure...
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for the pic and info, nice piece.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
that's nicer than mine...I used a cat one...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Talked about this in my build thread....
https://ty4stroke.com/threads/my-rt...let-the-mods-begin.149801/page-2#post-1384080
Dan
Dan
marc001
- Sep 28, 2013
- Howard City MI
- 2014 Yamaha Apex SE 2017 Yamaha SideWinder LTX LE
Is that plug for charging battery, like the Apex plug in?Talked about this in my build thread....
Dan
