berge75
Glue a good sized magnet to the chain case cover on the outside. It will hold the filings against the cover,on the inside, where the magnet is mounted.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Ok...i figured id post this LINK,which another member(favarcat)found.....
This is a site that sells PLUG BOLTS that have magnets...I think this will be the best route here...we just need someone to figure out the exact size of the drain plug.....check this link.
http://www.cgenterprises.com/magneticdr ... metric.htm
Dan
Dan
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
I haven't looked at the dipstick on my 2007 Apex, but I was under the impression that the end of the dipstick was magnetic. I know it is on my son's Viper, and the Apex service manual say it is too.
sawsalesman
I guess I need to check mine when I get home. Seems silly not to have one on there.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Apex and Attak do not have magnets on dipstick.
Tom-RX1
I had one of them magnets come off on my 2000 sxr . Grind that sucker up and try and get it cleaned out . Good thing it was still on warrentie .
Tom-RX1
Tom-RX1
BigMac
- Jun 27, 2004
I haven't actually checked mine yet, but here's a snap of the RX service manual under chaincase maintenance:TBay Sledhead said:Apex and Attak do not have magnets on dipstick.
ReX
ROCKERDAN said:Ok...i figured id post this LINK,which another member(favarcat)found.....
Dan
Good idea. I'll have to remember to measure the bolt when I take it out next time. I changed the oil last week so it will be a while.
vice108
Tom-RX1 said:I had one of them magnets come off on my 2000 sxr . Grind that sucker up and try and get it cleaned out . Good thing it was still on warrentie .
Tom-RX1
Same thing happened on my SRX
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
ReX said:ROCKERDAN said:Ok...i figured id post this LINK,which another member(favarcat)found.....
Dan
Hey REX....
I was hoping someone like you would check,LOL....i know you know your stuff and wont have us ordering wrong part..lol
maybe Ill do mine(even though i dont need to) and take the exisiting bolt to my local supply shop and have him tell me exactly what the size is...i think the magnet idea is awesome and we really can all benefit from it...maybe even buying a whole whack of them for us members to have cheaply....
Dan
Mikey
- Thunder Bay Ontario
- 03 RX-1
The drain bolt is pretty close to the back of the gear and chain the drain bolt with A magnet would have to be flush with the chaincase I believe. Gluing A magnet to the outside of the chaincase cover is prolly the best idea.
SharkAttak
anyone try this yet?
SharkAttak
anyone find the part # of the plug with the magnet in it
MCDuke
The drain plug in the chain case is M8 x 15 mm long. I looked at the link Rockerdan posted and there was no plugs under the size M12. M is metric threds, 8 is the diameter of the plug. so the M12 is 4 mm to large in diameter.
SharkAttak
MCDuke said:The drain plug in the chain case is M8 x 15 mm long. I looked at the link Rockerdan posted and there was no plugs under the size M12. M is metric threds, 8 is the diameter of the plug. so the M12 is 4 mm to large in diameter.
thanks
