power comander problem/ fuel problem? HELP
dieselmatt1
macomb, michigan
still have a fuel problem going on - anything over 70mph and 4lbs no fuel?
do u think the power comander has lost program
both fuel pumps are working
everything is pluged in and double checked everything besides comander
if you roll into throttle it sees 4lbs of boost if u give it full throttle it just pops not getting fuel?
yes it does have a afe gauge ,
any guesses?????????????
Just sent you a PDF for trouble shooting as well as maps. We'll get ya up and goin!
Could Also Be Spark Blow out, this will give a lean reading on the O2 sensor.
An O2 sensor is just that, it is not a Fuel sensor, so when you have a misfire it will Read Lean
Pull the plugs, close the gap to .025 also check the coils for any moisture build up or corrosion.
Ted.
