Gongshow77
- Sep 14, 2015
- 2014 Sr Viper XTX
I have a guy that sent me a map he got for his power commander 5 and it won't load onto mine. Just wondering if the maps can be locked or if there is another reason why it's not working? Thanks!
Never heard of that. Check the file designation should end with .pvm if not try changing it.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
If it's a Nytro PCV instead of a SR Viper PCV (they will both plug into either sled & work), then they won't load correctly.
Gongshow77
- Sep 14, 2015
- 2014 Sr Viper XTX
I believe it's an sr viper pcv. The error message was The device model number does not match the map model number. Device #429 vs. map #285
- Apr 17, 2003
- Menno, SD
- Menno, SD
That's a map from a Fx Nytro Pcv (285) & you have a Sr Viper Pcv (429). Open the map, go in the upper left corner of the map to select the whole map, then right click & copy it, then click get map and go to upper left again, right click & paste it to the map, then send map.
Gongshow77
- Sep 14, 2015
- 2014 Sr Viper XTX
Awesome I'll give that a try! Thanks!
Hey Allan everything works Awesome on mine too! Thanks for the help.
