Where can I tap power for an AF gauge at on my Nytro?
Saskapex
Can get it right from the key switch. There will be a switched b+ whenever the key is on.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Saskapex said:Can get it right from the key switch. There will be a switched b+ whenever the key is on.
Red/White wire if my memory serves me right
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I recommend drawing Power directly from the battery. Wire from battery thru a 30 amp fuse and thru a relay to the AFR system.
Use a relay to switch on Power on, you can use the wire from the ignition switch or if you want a delay from the head light wire, as long as it's a positive lead wire.
